Turntable Animation script needed
Greetings!
Basically, what we need is to be to import from a max file with a single object, create a camera that flies around it, and output an animation. This has to be done about 3600 times, so a script that can work on a directory is mandatory. Bonus points if you can output a gif animation.
We have a full spec for the project that can be sent to top-notch scripters, please submit an approximate amount to do the project, and a list of scripting projects that you have completed.
Thanks!
Doug
Done with this yet? I have
Done with this yet?
I have a scene done at home I can turn into a plugin if you want. I usually just center my object then merge the scenes but I can automate it for you if you're buying lunch.
I can do this. The list of
I can do this. The list of my public scripts you can see at www.scriptattack.com.
Mailed you.
