[request] polyOp
hi
i got a tiny problem with my script
i'm reading parameters out of a *.txt file and i'm using those to create a spline with severals knots.
this spline is converted to a editpoly obj.
well .. within the same script i want to extrude the face i got form the spline/editpoly conversion .. but i allways get an error with the message
"face list out of index .. or something simmilar" ..
the strange thing about it is - if i just do all these steps without the extrusion, and manually adding the same code for extrusion after the script finished .. i dont
get any errors
would be glad about help
cheers
masse
script works now ... thanks
script works now ... thanks once more
Thank you! I'll have a try
Thank you!
I'll have a try :)
... maybe I should simply follow the rule that says "never work after 3 a.m." *smile*
cheers
markus (munich/germany)
lol, that's a good rule
lol, that's a good rule =P
cheers
Well seems that the way you
Well seems that the way you are doing it you are not really creating any faces, and so you can't extrude them. What about using an extrude modifier?
pointArray = #([0,0,0],[5,0,0],[5,5,0],[0,5,0],[-5,2.5,0])
fn createPolygons tmpArray =
newSplineShape = SplineShape()
addNewSpline newSplineShape
for thePoint in tmpArray DO
addKnot newSplineShape 1 #corner #line thePoint
newSplineShape.name = (tmpArray[tmpArray.count - 3]) as string
close newSplineShape 1
updateShape newSplineShape
addModifier newSplineShape (extrude height:10)
myPoly = createPolygons pointArray
fn _createPolygons tmpArray
fn _createPolygons tmpArray =
-- the folling pointArray is being filled in
-- original script ... no need for showing you
pointArray = #()
-- create Polygon Object
-- do a spline object 1st
for h = 1 to pointArray.count do
addKnot newSplineShape 1 #corner #line pointArray[h]
newSplineShape.name = tmpArray[tmpArray.count - 3]
-- convert to Editable Poly
newEditPoly = convertToPoly newSplineShape
-- return
newEditPoly
myPoly = _createPolygon myArray
well ... i wanted to use the newEditPoly to extrude it ... but as I told oyu .. this doesnt work
polyOp.extrudeFaces myPoly #{1} 10.0
-- doesnt work ...
thx for help
masse
Probably some mixup with
Probably some mixup with either the variables or the variable scope. Any chance you can post the code or at least the relevant part?
