Forum topic · ScriptSpot How To
Unable to Apply UVW Map on multiple Selection with simple MaxScript
By v1ncent87 · 2015-07-07
Hi all,
I've recently created a maxscript to apply a 10x10x5m box UVW Map on objects.
I copied the code from the maxscript listener after applying it manually on an object. Edited some of the information to better organize it in my CUI. The code goes like this
macroScript UVW10x10x5m
category:"1Essential Scripts"
toolTip:"UVW10x10x5m"
Buttontext:"UVW10x10x5m"
	modPanel.addModToSelection (Uvwmap ()) ui:on
	$.modifiers[#UVW_Map].maptype = 4
	$.modifiers[#UVW_Map].length = 10000
	$.modifiers[#UVW_Map].width = 10000
	$.modifiers[#UVW_Map].height = 5000
After that, I set a shortcut key for it in my CUI for easier access while working.
It works perfectly when I use it on a single object. However, when using it on multiple object I get the below error
"-- Unknown property: "modifiers" in $selection"
pardon the noobish terms I used in my questions.
I tried to search for a similar script for reference, however the scripts I found looks very complicated. Is there a quickfix for this script or will the script need to be in a totally different "format"
Many thanks in advance!
tiagodmed
Use this:
With instances modifier:
Uv= Uvwmap()
for i in selection do
addModifier i ( Uv)
i.modifiers[#UVW_Map].maptype = 4
i.modifiers[#UVW_Map].length = 10000
i.modifiers[#UVW_Map].width = 10000
i.modifiers[#UVW_Map].height = 5000
Without instances:
Uv= Uvwmap()
addModifier i (copy Uv)
