There are 2 themes currently available on ScriptSpot - a light blue theme and this default dark theme. If you prefer a light one you can change the theme in your "My account" page.
Now click the "Edit" tab, and scroll toward the bottom where you'll see a section called "Theme configuration" where you can select the theme to use and see a sample of each one.
Now just click the "Submit" button to save your changes and your theme preferences will be saved.
