Forum topic · ScriptSpot How To
Attaching objects by list
By kevin mutiso · 2012-12-03
Hi guys, anyone kindly guide me on how to attach multiple objects to an editable poly, without making a selection in the viewport, but attaching them by list. Any help highly appreciated. thanks
ps. I've gone through previous similar posts but couldn't get a similar scenario.
Comments (8)
kevin mutiso
hey barigazy,
I finally got it working. you were right, attachlist is a bit complicated so I'm using the first method. It looked intimidating at first but I've managed to figure most of it out, maybe coz I'm a n00b. I appreciate the help… ill be posting the script once I'm done. cheers!
Try this
fn geoFilter obj = isKindOf obj geometryClass and not isKindOf obj TargetObject
fn attachSelections nodesArr = if isKindOf nodesArr array and nodesArr.count >1 do
local cnt = 1
local poAttach = polyop.attach
if not isKindOf nodesArr[1] Editable_Poly do convertToPoly nodesArr[1]
while nodesArr.count > 1 do
cnt += 1
poAttach nodesArr[cnt-1] nodesArr[cnt]
deleteItem nodesArr cnt
if cnt >= nodesArr.count do cnt = 1
) ; nodesArr[1]
theObjs = selectByName title:"Select Objects" buttonText:"Attach!" filter:geoFilter showHidden:true single:false
attachSelections theObjs
Reply to Branko Živković
kevin mutiso
thanks barigazy, I'll try & decipher that into my macroscript. i'll provide some feedback soon as I'm done. thanks alot
kevin mutiso
FEEDback
hello barigazy, I've tried to implement your script utilizing 'iskindof' function but I'm miserably lost. However I came across this in the 3ds maxscript help docs. under Attach/Detach methods>
AttachList <&node array>nodesToAttach editPolyNode:
...when I attempt to use AttachList as outlined in the document I get syntax error. please advise. thanks in advance
Reply to kevin mutiso
AttachList method is interface operation of Edit_Poly modifier
To perform this operation you need to be in modifier panel.
This is the first of many disadvantage.Use my method (fester for sure).
example editPoly attach list method:
boxObj = Box isSelected:on
addmodifier boxObj (Edit_Poly())
sphObj1 = Sphere pos:[-30,30,0] radius:5
sphObj2 = Sphere pos:[30,-30, 0] radius:5
sphArr = #(sphObj1,sphObj2)
max modify mode -- if u use "max create mode" then code not works
boxObj.Edit_Poly.AttachList &sphArr editPolyNode:boxObj
kevin mutiso
hey barigazy,
