XY extrude
By harumscarum · 2012-06-22
would be great to have tool to extrude spline in XY axis, modifier possibly...
obaida
The Right Question :
How to change the (normal) of line so the direction of extrude modifier will change also .
OR :
(making the extrude modifier have an option like local X,Y,Z direction)
in this way there is no need to attatch the line to another one with correct normal direction .
extrudeXY
This fn do the right job.
Options:
*theShape - spline that you need extrusion
*offset - extrude/offset value
*type - choose three type of extrusion:#center, #in or #out pivot alignement
*banking along the spline (on or off)
fn extrudeSplineXY theShape offset: type: bank: = if isKindOf theShape Shape do
local ext = offset as float
profile = SplineShape pos:(point3 0 0 0)
addNewSpline profile
addKnot profile 1 #corner #line (point3 (ext/2) 0 0)
addKnot profile 1 #corner #line (point3 (-ext/2) 0 0)
updateShape profile
local sweepMod = sweep CustomShape:1 GenerateMappingCoords:on Banking:bank
case type of (
(#center): sweepMod.PivotAlignment = 4
(#in): sweepMod.PivotAlignment = 7
(#out): sweepMod.PivotAlignment = 1
sweepMod.shapes[1] = profile
addModifier theShape sweepMod
delete profile
extrudeSplineXY $ offset:10 type:#in bank:on
Willian Kim
This is a way for you to develop your tool...
fn extrudeLine ey ez =
sel = $
applyOffset $ ey
select sel
modPanel.addModToSelection (Extrude ()) ui:on
$.modifiers[#Extrude].amount = ez
extrudeLine 5 10
Good Luck
obaida
sweep modifier can do this job .
