Hello
I'd like to know if anybody have already/want to do a script to set working pivot by 2 clicks : one for position, second one for x axis (for eg).
Could be really usefull. Thanks. :-)
working pivot by 2 points
By titane357 · 2010-12-18
Comments (7)
hello
Thanks for your efforts. Sorry for my silence I was busy...
"I think simply switching to the rotate tool (E) would be a better idea after
the pivot is placed "
Yes. But I'm precision addicted, and I would like to align X direction with a snap click on a vertex...
I can use other tools to rotate precisely, but the tool will be a pain to use...
I was playing around a bit, and it seems that the option to activate the "Surface"-Button in the edit working pivot options is broken. Maybe someone can test that?
does not do anything for me.
I have found a weird workaround (based on Ian Farnsworth SkinReset Script) to press that button via MAXScript:
If you put that into a macroscript and then into a quad menu / toolbar it might be saving some time.
Now I still dont really know what you mean with that second click. Should it rotate on x Axis for 90 degrees depending in the direction of your mouse cursor or...? I think simply switching to the rotate tool (E) would be a better idea after
the pivot is placed.
Cheers
nice tip
Hi Br0t,
yes,
function is broken.
Its not even described in the help, and I need to call
to see that it exist.
Nice UIAccessor tip.
It is described in the Max 2011 Help files though:
Good to know its not only me where its not working ;)
poor docs in Max 2009
Yep, in my Max 2009 help files exist only this :)
what do you mean exactly? first click would set the working pivot to the position you have clicked on, and second click would do...?
hello, thanks for reply :-)
It is "easy" to positionnate working pivot on a vertex, but it very difficult to set its rotation easily.
The two clicks should determinate a direction : X axis for example.
Yes a third click could set the Y axis ?
