Is were a script, which purpose is select an objects visible in viewport
visible in viewport selection
By anybany · 2007-05-03
Try this. This script will select all objects whose positions are visible from the current orhtographic viewport. Use this as a starter and feel free to ask questions.
Hope this helps
Mobeen
--Author: Muhammad Mobeen Movania
--Last Modified: May 04 2007 10:28 pm PST
--Tested on 3dsmax5
--This script selects all objects that intersect the current
--orthographic viewport limits
try( destroydialog r_Test)
catch()
rollout r_Test "Select Visible to Viewport"
fn fnFindMinMax pts &minX &maxX &minY &maxY =
minX = pts[2].x
minY = pts[2].y
if (pts[1].x <= minX) then
minX = pts[1].x
maxX = pts[2].x
maxX = pts[1].x
if (pts[1].y <= minY) then
minY = pts[1].y
maxY = pts[2].y
maxY = pts[1].y
button bSelect "select"
on bSelect pressed do
--Get the active viewport size
local vpSize = getViewSize()
--Get the view bounds
local pts = #([0,0], vpSize)
--This will contain the viewport points in world coordinates
local tfm = #()
--Transform viewport points into the world positions
for p in pts do
append tfm (mapScreenToCP p)
local minX = 0
local minY = 0
local maxX = 0
local maxY = 0
fnFindMinMax tfm &minX &maxX &minY &maxY
print ("Min " + minX as string + ","+minY as string) print ("Max " + maxX as string + ","+maxY as string)
--Remove previous selections
clearSelection()
--Loop through all geometry and find if the geometry is inside the
--viewport limits
for g in geometry do
if ( g.pos.x >= minX and g.pos.x <= maxX and
g.pos.y >= minY and g.pos.y <= maxY) then
--add to selection
selectMore g
createdialog r_Test 200 40
