vertex corner align
By airbrush · 2013-01-22
Comments (24)
Since miauu's Script Pack v. 1.0 all updates are free. I released miauu's Script Pack with 10 scripts, now they are 14. For miauu's Work Plane the situation is the same - all next versions are free for the people that purchased the script.
You can ask the author of Wall Worm Model Tools. He has both my commercial scripts from their first version and can confirm that all updates are free.
There will be no free version. :)
Reply to miauu
this tool can't be free. In this faze, maybe but Kostadin always update all tools in his "powerful" pack so...
Reply to miauu
airbrush
(tear streams down) :(
....seriously though, great work on the scripts, was just checking out your videos, the scale and clone/spacing tools look great.
So if I buy your script pack and you add more scripts to it at a later date. Is it going to be a free update for those that have purchased the pack?
Just thought maybe the tester and suggestor would get a free version :)
thx
Reply to miauu
Congrats Kostadin, "smart" corner align is awesome.
One suggestion - add checkbox for preserving UVs.
Cheers!
I will add it in the next version along with the ability to use the object local coordinate system. :)
Reply to miauu
airbrush
were you planning on releasing a free version of the script separately from your script pack? Just curious.
I rewrite the script last night. See how it works now:
I
I think that I can add one more stuff and will release it. :)
airbrush, can you show/send me pictures to show how you want the script to works when one section is rotated?
The final version will support edge align and weld. Multiple slected verts align and weld are already done.
Reply to miauu
airbrush
The new version will have multiple vert select...great...very tedious without.
Also noticed it works great if you are doing things on 90 degree angles to each other...just as a test tried with one section rotated and when you align it doesn't go in line with edges but gets averaged a little.
The edge align will fix this i assume?
Yep. I will include it in my script pack when I have time to polish it.
Reply to miauu
I assumed that was the reason.It will be the powerful tool for sure.
Also you may include edge weld.
Hi, airbrush!You have only
Hi, airbrush!
You have only one link in the post. :)
See the gif image how the CornerAlign_01 script works.
The script automaticaly weld the selected vertices.
Reply to miauu
But encrypted script ... Never mind. Works very well.
Regards!
Reply to miauu
airbrush
thanks again...this will be very helpful...will give it a whirl. Does it do muliple selected verts at once?
Reply to airbrush
That's why I suggest edge weld.Something like sline options (fuse and weld at once)
