I have really only done basic expressions before in wire parameters so I don't even know if it is possible, but I have a bunch of shapes setup with a bunch of modifiers.
Basically want it to do is globally check
If a Dummies rotation is equal to multiple of 90 degrees on any axis
then switch modifiers on
specifically Face Extrude on/off or amount 0/100
and
ScalpelMax on/off or Kill and Fill check boxes on/off.
if not then keep them off
Any help would be greatly appreciated
Thanks in advance.
Thanks a lot Miauu, will give it a try.
The ScalpelMax is commersial modifier and I do not have it, so try to adapt the code for scalpelMax as it is for face_extrude
About animation - I don't know. Try it.
thanks for the reply miauu.I
I would want it to turn off all the face extrude and all of the scalpelmax modifiers in the whole scene.
Also they just listen to one specific dummy.
So would it work that if the dummy is animated that it will switch the modifiers on and off as the timeline progresses?
Thanks again
This will print in the listener the name of dummys which rotation is equal to multiple of 90 degrees on any axis:
I use this:
because,sometismes MAX use -2.28882e-005 instead of 0.0.
I can'r understand which modifiers you want to turn on/off - all Face Extrude mods in the scene(mean on all objects that have this mod) or this is related to the Dummy, that is processed.
