Hi Everyone,
I am looking for a simple way to have a text object update based on a file that contains a frame number and string (numbers, letters or combination).
I would like to be able to run the script so that at each frame number, a text object will update with the respective string at that frame.
I imagine some of your are probably shaking your head at this one, but I have very limited exposure to Max Script.
My text file could be anything like this:
frame show text
0 113
1 1234
2 1579
3 1321
...etc
Any help is appreciated.
Eugene
My bad...this works like a charm!
Thanks so much!
Eugene
Glad to here that code works because I not test this but anyway... :)
Always try to run any code from listener or mxs editor by opening it first and then execute ei.evaluate.
Cheers!
I ran this under "Run Script" and it gave me a
No "eof" function for undefined
Let say we have text file "data.txt". Content look like this:
0 "max2014"
1 "maya2014"
2 "mudbox2014"
3 "adobe illustrator cs6"
4 "softimage XSI"
5 "ZBrush"
6 "VRay"
7 "Maxwell"
8 "Octane"
9 "Modo"
10 "Nuke"
Runing this code you will get what you need
delete objects
txtShape = text()
fn showTxt txtObj txtFile: =
local theCtrl = float_script()
theCtrl.addNode "txtObj" txtObj
local frameArr = #(), txtArr = #(), dataF = openFile txtFile
slidertime = 0
while not eof dataF do
append frameArr (readValue dataF)
append txtArr (readValue dataF)
close dataF
theCtrl.AddConstant "fVals" frameArr
theCtrl.AddConstant "tVals" txtArr
theCtrl.SetExpression "if (idx = finditem fVals f) !=0 do txtObj.text = tVals[idx]\n0"
txtObj.kerning.controller=theCtrl
free frameArr ; free txtArr
-- change file path if your file have different location on HDD
showTxt txtShape txtFile:@"c:\\temp\\data.txt"
playAnimation()
