Turn ON 1 layer, and turn off 4 the other, automatically
By igamaximus · 2018-01-23
Hello guys,
i have some bigger work in progress and now i would get great use of this functionality to speed up some really tedious tasks...i would really appreciate your help on this topic:
I have 5 layers with most simple naming convention: Layer01, Layer02, Layer03, Layer04 and Layer05....and i need to have one of them turned on, and the rest of them (with this naming convention) turned off automatically, with the click of the button. I would appreciate one case from you, for example for Layer01, and after that, i would modify the script and create several versions of the code, for other layers.
Please see if you can help me with it.
Thank you very much in advance...
Comments (12)
1rv
Can't you just set up some Scene states with desired layer config?
Reply to 1rv
igamaximus
Scene States vs. Max 2012
I would love to do that , but since i am because of some tools still on Max 2012 x64 and Scene States are painfully buggy (or better say useless) in that version, unfortunately that is not an option for me...
Make tha layer that you want to be ON active. Then run the code. All other layers will become OFF(objects will be hidden). If you want to turn ON other layer - make it active and run the code
	curLayer = LayerManager.current
	curLayer.isHidden = false
	for i = 0 to LayerManager.count - 1 where ( (idx=(LayerManager.getLayer i)) != curLayer) do
		idx.isHidden = true
Reply to miauu
igamaximus
Thank you Kostadin!
Beautiful idea mate, thank you so much for your help!
Now, this works really perfectly except that it works for all layers in the scene. I have some layers, outside of my naming convention that i don't want to be turned off, so please see if is possible to add this functionality to all selected (highlighted on the layers list) layers...this would be so perfect, and if this is not possible...to keep this functionality but only for layers of certain naming convention (ideally, it would be great if i could add number of layers, and layer names in the script).
Thank you so much once again Kostadin, for your quick help and great idea...
Reply to igamaximus
The code below works only with 3ds Max 2015 and newer version.
	layerMngr = SceneExplorerManager.GetActiveExplorer()
	layersArr = layerMngr.SelectedItems()
	if layersArr.count != 0 do
		for layer in layersArr do
			layer.isHidden = true
Select the layers you want to turn OFF and run the code. The active layer will remain ON no matter if it is selected or not, so the layer you want to stay ON must be set as active.
Reply to miauu
igamaximus
Perfect!
Thank you so much!
This one works perfectly mate!
Thanks a lot for your kindness and knowledge!
Reply to miauu
igamaximus
Kostadin,
this is beautiful workflow, but just for the sake of my specific workflow here, can you please write me variant of script where only "Layer01" is turned on, and layers "Layer02", "Layer03", "Layer04" and "Layer05" are turned off, regardless if any of these is selected or not, regardless of current layer, and regardless of any other layer that may be turned on or off? Please!
And if possible, i would like to assign toolbar button to this function so i can do this with 1 click, without even opening Layer Manager...
Thank you!
Reply to igamaximus
Save this as a .ms file. Drag and drop it in 3ds Max viewport. Go to Customize-Customize User Interface-miauu category and create a toolbar button.
macroscript turnLayersOnOff
category:"miauu"
tooltip:"Turn Layers On/Off"
buttonText:"Turn Layers On/Off"
	(layerManager.getLayerFromName "Layer01").isHidden = false
	(layerManager.getLayerFromName "Layer02").isHidden = true
	(layerManager.getLayerFromName "Layer03").isHidden = true
	(layerManager.getLayerFromName "Layer04").isHidden = true
	(layerManager.getLayerFromName "Layer05").isHidden = true
Reply to miauu
igamaximus
Yes!!!!
That's it,
that does the job perfectly!
Thank you so much Kostadin for this, and many, many of your other beautiful tools!
All the best!
Igor
Reply to miauu
igamaximus
SHIFT + click to cycle
Kostadin,
can i please ask you for one more addition as i realized this would be the fastest here:
can you please revise this last code (with toolbar button), so when i hold SHIFT key, and press toolbar button, the script would "cycle" on the next layer (turn on next layer, and turn off all the others)?
For example, Layer01 = true and Layers02-05 = false....now when i press the button for the first time, Layer01 will be on, and Layers02-05 will be off. But further, when i hold SHIFT and press the button each next time, next layer (Layer02, Layer03,...up to Layer05) will be ON, and all the others will be off? Would it be too hard to add this?
Thank you so much...
Igor
Reply to igamaximus
category:"miauu"
	if keyboard.ShiftPressed then
		layersArr = #("Layer01","Layer02","Layer03","Layer04","Layer05")
		stopLoop = false
		for i = 1 to layersArr.count while stopLoop == false do
			if (layerManager.getLayerFromName ("Layer0" + (i as string))).isHidden == false do
				stopLoop = true
				for j = 1 to layersArr.count do
					(layerManager.getLayerFromName layersArr[j]).isHidden = true
				if i == layersArr.count then
					(layerManager.getLayerFromName layersArr[1]).isHidden = false
					(layerManager.getLayerFromName layersArr[i + 1]).isHidden = false
Reply to miauu
igamaximus
5x faster!
Kostadin,
this is pure perfection, can't thank you enought for this...
I have used it all day long during the project and i am able to achieve 5x speed improvement comparing to manual clicking in layer manager dialog! Looping is perfect also, exacly what i need!
Thank you SO very much...and also, thank you so much for updating your Spline Deformer - the best tool of its kind for sure!
Wish you all the best with your work and new tools,
Igor
