Switching object properties>renderable on and off from attribute holder
By savas cetin · 2012-09-14
Hi
I want to switch objects renderable property on and off from attribute holder.
I can switch off renderable property by maxscript by "$.renderable = off". how can I connect this property to attribute holder.
Thank you
savas cetin
Thank you again
try this
rendOnOffCA = attributes rendOnOff
parameters main rollout:roll
rend_on_off type:#boolean animatable:false ui:cb_on_off default:on
rollout roll "Parameters"
checkbox cb_on_off "Renderable"
on cb_on_off changed state do ((refs.dependentNodes (custAttributes.getOwner this))[1]).renderable = state
emptyMod = EmptyModifier name:"Render Switcher"
obj = Box()
custAttributes.add emptyMod rendOnOffCA
addmodifier obj emptyMod
Reply to savas cetin
This is better solution using function.
Just select object and run code below
fn addRenderSwitcher obj =
currobj type:#maxObject
--this.currobj = (NodeTransformMonitor node:obj)
on cb_on_off changed state do currobj.node.renderable = state
emptyMod.currobj = nodeTransformMonitor node:obj forwardTransformChangeMsgs:false
addRenderSwitcher $
