Hello,
I am trying to add sweep modifier with custom builtin shape, length and width, pivot position
single object work . . . ok!
but when selection two or more shapes or editable spline getting error
can any one solve
Thanks,
if selection.count > 0 then
for obj in selection where isKindOf obj Editable_Spline or isKindOf obj Shape do
--modPanel.addModToSelection (sweep ()) ui:on
addModifier obj (Sweep())
$.modifiers[#Sweep].CurrentBuiltInShape = 2
$.modifiers[#Sweep][#Bar_Section].length = 0.002
$.modifiers[#Sweep][#Bar_Section].width = 0.002
$.modifiers[#Sweep][#Bar_Section].cornerRadius = 0
$.modifiers[#Sweep].PivotAlignment = 4
Comments (7)
Thanks you guys
yes both working good . . . .
thank you so much
Another approach
Much better Approach
Well done Barigazy :)
This approach is much faster when applied to a large amount of shapes.
Getting error . . .
getting error please check . .
-- Error occurred in anonymous codeblock; filename: ; position: 132; line: 3
-- No ""get"" function for undefined
-- MAXScript callstack:
-- thread data: threadID:2236
-- [stack level: 0]
-- In anonymous codeblock; filename: ; position: 272; line: 6
-- Locals:
-- Profile: undefined
-- modi: sweep:Sweep
-- nodes: undefined
-- Externals:
-- addModi: Global:addModi : addModi()
-- [stack level: 1]
-- called from top-level
nodes: undefined
it seems that you don't have any valid node selected, "nodes= getCurrentSelection()", shouldn't return undefined.
you can use this, it will send a message instead of crashing, i've also changed how nodes array was built, it now filters only shape objects and i removed shape filtering in the mapped function as it is no longer needed,earlier version was crashing if a non shape object was selected:
thanks Simon . .
Hello
will check and revert you
thanks
