swap objects´s visibility
By jsrocha · 2015-06-10
Hi guys, how’s going? i was wondering if is hard to create a simple script to swap objects's visibility. I need this to compare different versions of a model (architectural). I used to do it with scene states, but i don´t know why, the scene states tool stopped working in max (2104). I´ll try to explain what i think: let´s say i got two versions of a building, so i can select the first one and set it as 1, and then select the other and set it as 2. And a swap button will hide one and unhide another every time i click in the button (something like this - http://prntscr.com/7fcppv). I use a similar technique in autocad to compare projects, and it works very well, it´s a good way to find differences between drawings. Can anyone help me with this?
thanks,
Jsrocha
Reply to pixamoon
jsrocha
Thanks!
Hey Pixamoon, thanks for the script, works pretty fine!
Cheers,
Jsrocha
