Subobjects selection located at exact coordinate or coordinate range, like select all vertexes in Z: from 0.0 to 0.1. In this case I need to select all the flat surface of the mountains object.
By Duka · 2016-07-07
If you are not familiar with sub object selection, you can select it by holding [ctrl] and click your mouse. The most common sub object I use in the past is vertex. If you select an object without activating any tool, then you will see the object’s vertices.
mxs
Or download attachment
editable poly object?
yes
Here we go (copy this in MXS Editor and save it as *.ms)
try(destroyDialog ::xxxRoll)catch()
rollout xxxRoll "Select Subs By Range"
fn inBetween val axis vmin: vmax: =
case axis of
1: val.x > vmin and val.x < vmax
2: val.y > vmin and val.y < vmax
3: val.z > vmin and val.z < vmax
fn selectInRange sub:1 axis:1 minval: maxval: range:on = if selection.count > 0 do
local selectSub = if sub == 1 then polyop.setVertSelection else polyop.setFaceSelection
local getPos = if sub == 1 then polyop.getVert else polyop.getFaceCenter
with redraw off for node in selection where isKindOf node Editable_poly do
object = #{}
number = if sub == 1 then node.numverts else node.numfaces
for i = 1 to number do
e = getPos node i
if range then (if inBetween e axis vmin:minval vmax:maxval do append object i) else
e = case axis of
1: e.x
2: e.y
3: e.z
if e == minval do append object i
selectSub node object
spinner spn_min "min: " pos:[3,3] range:[1e-9,1e9,0] fieldwidth:100
checkbox cb_usemax "" pos:[140,3] width:15
spinner spn_max "max: " pos:[155,3] range:[1e-9,1e9,10] fieldwidth:100 enabled:off
label lbl_axis "Axis:" pos:[3,23]
radiobuttons rb_axis "" pos:[30,23] labels:#("X","Y","Z") columns:3 default:3
label lbl_sub "SubLevel:" pos:[140,23]
radiobuttons rb_sub "" pos:[195,23] labels:#("Verts","Faces") columns:2
button btn_doit "DOIT" pos:[297,3] width:35 height:35
on cb_usemax changed state do spn_max.enabled = state
on btn_doit pressed do
if GetCommandPanelTaskMode() != #modify do SetCommandPanelTaskMode #modify
selectInRange sub:rb_sub.state axis:rb_axis.state minval:spn_min.value maxval:spn_max.value range:cb_usemax.checked
subobjectlevel = if rb_sub.state == 1 then 1 else 4
createDialog xxxRoll 335 40 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
