hello , my god
i am seeking convert lights
standard light to vray sun or ies sun conver
is there good idea ?
By dussla · 2012-07-21
hello , my god
With this little script you can align vray sun to any object which have target.
Just select a object (camera, light etc.) and press the button.
try(destroydialog ::AlignVRSUN) catch()
rollout AlignVRSUN "VrSun Align"
fn check obj = isValidNode obj and obj.Target != undefined
button avrsun "Align VRay Sun" pos:[5,5] width:110 height:20
on avrsun pressed do
local vrsun = (for s in lights where classof s == VRaySun collect s)[1]
if vrsun == undefined then (messagebox "VRay Sun don't exist." title:"Note" beep:false) else
if selection.count != 1 then (messagebox "Select a object first!" title:"Note" beep:false) else
local targObj = selection[1]
if check targObj == false then (messagebox "Select a node which have a target" title:"Note" beep:false) else
vrsun.target.transform = targObj.target.transform
vrsun.transform = targObj.transform
createDialog AlignVRSUN 120 30 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
The parameters of standard and vray sun light are too much different.Only position of light and light target need to be
the same in the case of converting.
yes, i want to place same postion
yes god ~
i know vray sun and standard parameter's differancy
i want to place same postion only ~
if you have a free time , i want to help me again
thank you , thank you always
