Snap all the selected spline object's vertex to viewport homegrid.
Spline vertex snap to home grid
By Andrew · 2013-02-08
I correct your script. Now works only with E-Poly, E-Mesh, and E-Spline objects without modifiers assigned.
try(destroyDialog ::vertSnap)catch()
Rollout vertSnap "Vert Fixer"
fn filtObj obj = (isKindOf obj Editable_Poly or isKindOf obj Editable_Mesh or isKindOf obj line or isKindOf obj SplineShape) and obj.modifiers.count == 0
fn roundP3 val sc: = ([(floor (val.x+0.5))*sc, (floor (val.y+0.5))*sc, (floor (val.z+0.5))*sc])
fn vertMove vs = if selection.count != 0 do
local poGetVert = polyop.getVert, poSetVert = polyop.setVert
local moGetVert = meshop.getVert, moSetVert = meshop.setVert
local ssGetKnot = getKnotPoint, ssSetKnot = setKnotPoint
for obj in selection where filtObj obj do
case of
(classof obj == Editable_Poly):
for v = 1 to obj.numverts do
vpos = poGetVert obj v
poSetVert obj v (roundP3 vpos sc:vs)
update obj
(classof obj == Editable_Mesh):
vpos = moGetVert obj v
moSetVert obj v (roundP3 vpos sc:vs)
update obj
(classof obj == line or classof obj == SplineShape):
for s = 1 to (numSplines obj) do
for k = 1 to (numKnots obj s) do
kpos = ssGetKnot obj s k
ssSetKnot obj s k (roundP3 kpos sc:vs)
updateshape obj
group "Snap verts:"
button fixVert1 "1 unit" width:60 across:3 align:#left
button fixVert2 "10 units" width:60
button fixVert3 "100 units" width:60
on fixVert1 pressed do vertMove 1
on fixVert2 pressed do vertMove 10
on fixVert3 pressed do vertMove 100
createDialog vertSnap 210 55
Man this is a real life saver!
Can't thank you enough!
Actually
I have this here script that snaps Editable polygon vertex to grid points.
Anyone could help convert it to snap spline vertex in much the same way?
( Also this script seems to have a small issue,
Need to run it twice for it to work.
group "Snap verts:"
button fixVert1 "1 unit" across:3
objEd = newRolloutFloater "Vert Editor" 245 450 50 50
addrollout vertSnap objEd
fn vertMove vertScale =
for K = 1 to selection.count do
if (selection[K].baseObject as string == "Editable Mesh") or
(selection[K].baseObject as string == "Editable Poly") do
for L = 1 to selection[K].numverts do
currentVert = polyop.getVert selection[K] L
currentVert.x = float currentVert.x/vertScale
currentVert.y = float currentVert.y/vertScale
currentVert.z = float currentVert.z/vertScale
if currentVert.x - (floor currentVert.x) < .5 then
currentVert.x = floor currentVert.x
currentVert.x = ceil currentVert.x
if currentVert.y - (floor currentVert.y) < .5 then
currentVert.y = floor currentVert.y
currentVert.y = ceil currentVert.y
if currentVert.z - (floor currentVert.z) < .5 then
currentVert.z = floor currentVert.z
currentVert.z = ceil currentVert.z
currentVert.x = currentVert.x*vertScale
currentVert.y = currentVert.y*vertScale
currentVert.z = currentVert.z*vertScale
polyop.setVert selection[K] L currentVert
update(selection[K])
Example from mxs help
new_z = 0 -- Z coordinate
for ss in selection where isKindOf ss line or isKindOf ss SplineShape do
for s = 1 to (numSplines ss) do
for k = 1 to (numKnots ss s) do
knt = getKnotPoint ss s k
in_vec = getInVec ss s k
out_vec = getOutVec ss s k
knt.z = in_vec.z = out_vec.z = new_z
setInVec ss s k in_vec
setOutVec ss s k out_vec
setKnotPoint ss s k knt
updateshape ss
Thanks but,, i made a mistake
Ops, Sorry, I guess that i should not have said homegrid.
should have said 2.5D snap to any viewport grid points.
So vertex snap to grid points. not just a flaten vertex to the home grid
