specfic layer delete fuction
By dussla · 2012-05-02
hi friends
i come here again for help
i am seeking layer delete function
example :
layer name is good-roof
i would like to delete that with script
can you help me again pls
mmb
want to delete Layer along with its content
hello
i want to delete some layers along with its content which contain geometry, light, cameras.
thanks for the Help!
Reply to mmb
	fn deleteLayerByName layerName =
		--set 0-layer to be current
		(layermanager.getlayer 0).current = true
		--find layer that you need to delate
		layerToDelete = LayerManager.getLayerFromName layerName
		if layerToDelete == undefined then (messagebox ("Layer *"+layerName+"* don't exist!!!") title:"DeleteLayerByName" beep:false) else
			layerToDelete.nodes &theNodes -- check if layer is empty then delete it
			if theNodes.count != 0 then
				delete theNodes
				LayerManager.deleteLayerbyname layerName
	--	"replace "Layer001","Layer003","Layer007" with the names of the layers you watn to delete. Add as many names as you want."
	layersToDeleteArr = #("Layer001","Layer003","Layer007")
	for o in layersToDeleteArr do
		deleteLayerByName o
Delete Layer By Name
This is your code (function):
if theNodes.count != 0 then (messagebox ("Layer *"+layerName+"* is not empty!!!") title:"DeleteLayerByName" beep:false)
else (LayerManager.deleteLayerbyname layerName)
deleteLayerByName "good-roof"
