Solidbody seeker
By Bruce Jones · 2012-12-18
In order to make the visibility track work in 2013 the object to be turned on and off muyst be a mesh, the track will not work on solidbodies. I can't find a standard feature to select solidbodies anywhere in the program, I believe this needs to have a script to do the job (my current animation has 4500 objects tha came out of Inventor, I have no idea which are meshes and which are solidbodies.
Bruce Jones
Solution
Simple and elegant, thanks.
Body_Object
for obj in geometry where classOf obj == Body_Object do format "% is solid body\n" obj.name
new to scripting. how would i add the geometries that it found to a selection and then do something to that selection. I am trying to edit display setting of all body objects. The script i have now I can only do by first selecting manually all of the body objects (pain). The internal body object utility just crashes max but I found if i run a max script it works. any ideas how to collect all body objects to a selection and then run an action like. $.DisplayRadioVDS = 1
