I am looking for, a script to snap, to point helpers.
3ds max 2016 x64
snap to helper point
By juzernejm · 2019-12-14
3ds max 2016 x64
Comments (10)
not working or im stupid noob xD
here is link to video which shows not working scripts
https://vimeo.com/403331733
and here in link to video which shows that's how I imagine it but working on helper point
https://vimeo.com/403335138
describing it like this
I have some object, vray proxy model or whatever.
I create a pont helper in the places designated by me on the model, then select the whole and create a group, and thanks to the snap helper point script I send created groups to other groups that also have a helepr point.
I assumed it would work.
i dont know hot to say/describe in english :/
I guess I am doing something wrong, in the new year I will show in an example film how I use it and you will tell me why it does not work ........ Where I make a mistake.
Yes, I know you did not expect me to have problems with something so simple. I do not disturb you during Christmas.
Ok, but how can i this use,
Ok, but how can use in 3ds max?;
Is it in the form of some window?
How to use it?
Maybe I didn't explain clearly (I'm sleepy), I mean snap helper point to helper point.
I don't know if it's something but somehow I think poorly today.
I have a stupid question.
Could you show me how to use it?
that's unexpected :) you ask for a script and even don't know how to use one
ok
you can either run it as is or make a macro out of it
then you can bind it to a hotkey for convenience
usage:
1. select object/s
2. execute script or macro using hotkey
3. pick the helper node where selection will move
No, snap to helper point only.
I will assign the appropriate point helper to the objects.
OK. But what have to be snapped to those helper points? Selected objects? Selected verts? Something else?
or
Maybe I'll say yes.I have
I have several hundred different objects that fit into my lego style, but not literally.
I want to build something out of them, and I came up with the idea of giving some point helpers to each object to make the fun easier.
Maybe I'll make some film for yt.
Sorry for any errors, I use google translate.
You want a script that will create point helpers and will put each point helper at the position of each of the selected objects?
What will be snapped to those help pointers?
