simple script creation
By ponchim · 2018-03-28
Hey everyone. Can someone help me out to create this simple script?
Basically that should be Bitmap / Photometric Path Editor window with additional column *usage (used or unused) and maybe status (Found or File missing).
Tried to use this script (http://www.scriptspot.com/3ds-max/scripts/zoa-path-editor) and it has almost everything that I need except for status.
But that script thinks that if texture has wrong path it's missing although it is not.
And offtop quastion does anybody know how to assing Bitmap / Photometric Path Editor window to HotKEY? In the keyboard list in 3d max I have found only Map|Photometric Path Editor but it's not opening the correct window.
Thank's
Reply to pixamoon
ponchim
Thanks a lot . Already waiting for you to add that line into your script. When it will be approx?
