Hello, I'm looking for a script like this one: http://www.scriptspot.com/3ds-max/scripts/toggle-hide. The link for this one is dead.
Those someone know one?
Thanks for your help
By Spline · 2019-12-06
Me again,
I've tryed your script and it have some issue.
1- The button layer's buttons must be emty or else at first because the 0 (default) layer cannot be renamed.
2- For some reason, some layers that was not choose, was activate also. Dose that depens on the name on those layers?
Thanks for your help :)
Here is the updated script: https://drive.google.com/open?id=1VbPN-kjY-GHzP8KZeh5bYM11otwRDn7S
It will not show layer 0 when you run it.
The "Toggle" button work as a toggle - the layers that are Off will be turned ON and the layers that are ON will be turned Off. The original script works the same way.
Thanks Miauu, exactly what I want!
Thanks Miauu, very appreciated
Almost what I want.
What about If I can choose multiple layers at the same time in the dropdown list? So I'm not limited to only two selection.
You can't do this with a single dropdown list. Multiple ddl have to be used. Here is a version that allows 10 layers to be choosen:
https://drive.google.com/open?id=1q3qUpxXTedTKSJ5J0wwT5dRiFjnAmblg
The link to the "Toggle Hide" script:
https://drive.google.com/open?id=1T8j3RmiYSeuEQD5y2KZpnHldShpV03U1
