need script which will improve polygon creation by Shift + Drag Edge
by default new polygon gets ID=1, is there any way to assign source polygon ID to a new one when dragging its Edge and hold Shift button
Shift + Drag Edge polygon creation with same ID as source polygon
By harumscarum · 2017-06-23
Ideas
I'd instead suggest posting to the 3ds Max Ideas, as a feature request.
Here is first test
It's rollout with timer - checking if new faces are created with Shift
One thing is - first need you need to release mouse button and nest Shift - if you release Shift first it will not apply ID's
Let me know how it works, and which MultiScatter properties should I add in next version.
Best,
Pixamoon
