Set U and V tiling of all Bitmap textures of selection
By Sketchup Master · 2024-08-27
Hello,
Here i am creating a script of Set U and V tiling of all Bitmap textures of selection
but script has bug and i can not solve it.
can any one correct the script
thanks
-- Function to set U and V tiling of all Bitmap textures in a V-Ray material to 1.0
fn setVrayMaterialTilingToOne mat =
-- Function to set tiling for a Bitmap texture
fn setBitmapTiling tex =
if classOf tex == Bitmaptexture do
tex.U_Tiling = 1.0
tex.V_Tiling = 1.0
-- Check and set tiling for all relevant maps in V-Ray material
if (mat != getClassInstances vraymtl) do
print mat
-- Diffuse map
if mat.diffuseMap != undefined do setBitmapTiling mat.diffuseMap
-- Bump map
if mat.bumpMap != undefined do setBitmapTiling mat.bumpMap
-- Reflection map
if mat.reflectionMap != undefined do setBitmapTiling mat.reflectionMap
-- Refraction map
if mat.refractionMap != undefined do setBitmapTiling mat.refractionMap
-- Specular map
if mat.specularMap != undefined do setBitmapTiling mat.specularMap
-- Self-illumination map
if mat.selfIllumMap != undefined do setBitmapTiling mat.selfIllumMap
-- Displacement map
if mat.displacementMap != undefined do setBitmapTiling mat.displacementMap
-- Coat map
if mat.coatMap != undefined do setBitmapTiling mat.coatMap
-- Check if the material is a Multi/Sub-Object material
if classOf mat == Multimaterial do
for i = 1 to mat.numsubs do
local subMat = mat[i]
setVrayMaterialTilingToOne subMat
-- Iterate over selected objects and set tiling for their V-Ray materials
for obj in selection do
-- local mat = getMaterial obj
local mat = getClassInstances vraymtl target:obj.mat
Simon Bourgeois
Try this:
	fn setBitmapTiling BitmapsArr  =
		for map in BitmapsArr do
			map.coords.U_Tiling = 1.0
			map.coords.V_Tiling = 1.0
	local matArr =#()
	local bitmapArr=#()
	for obj in selection where obj.material != undefined do join matArr (getClassInstances VRayMtl target:obj.material) --create an array for all VRayMtl,it collects all VRayMtl within multisub or blend or other type of materials
	for m in matArr do
		join bitmapArr (getClassInstances Bitmaptexture target:m) --add all Bitmaps to bitmapArr
		join bitmapArr (getClassInstances VRayBitmap target:m) --add all VrayBitmaps to bitmapArr
	makeUniqueArray bitmapArr --filterout bitmaps that have been collected multiple times (if the same bitmaps are used in multiple materials)
	setBitmapTiling bitmapArr --launch the function for every collected bitmaps
