Seperate meshes using specfic fields into layers and then Batch Export Seprate Meshes Into Layer Specfic Folders
By Adam · 2016-10-26
Hi everyone, ok what I am after i have seen in one form or another but not an all in one..
I would like to get all my meshes to separate into layers depending on what tags they have in the mesh's name, layers such as "Residential" or "Hotel" or "Retail" etc... once they are separated I can then assign them into levels manually (such as -01, 00, 01, 02 etc..) unless there is a way to also assign it automatically using level tags in the mesh name also?? after which the structure of the layers would like this...
00 Layer
-Resi
-Retail
-office
02 Layer
-Resi
-Retail
-office
03 Layer
-Resi
-Retail
-office
04 Layer
-Resi
-Retail
-office
Once the script has done this I would like to clean each mesh name down to just a number, for instance right now the mesh name would like this:
"6624.747240~Leisure 6624.747240~Leisure [2594735]"
- we basically managed to get Revit using Dynamo to export "rooms" with bits of info attached to each mesh. once we have cleaned it up so it's just showing the area number "6624.747240" I would then like to get all individual meshes to export as .fbx files,
BUT in to there corresponding level folder and sub category folder on my desktop / network location.
I am sure it is possible but then again I have no idea how to script in 3dmax!
any insight, or someone who would like to make this?
Adam
Thanks fajar - however I am not trying to learn how to do this, I would like this script made for me, I am happy to pay for it but I do not have the time to learn it my self (currently teaching my self three other programs!)
fajar
how about you learning mxs first...
how about you start rename object first...
lets start
-- if you have only one box selected then write this
$.name = "Hello box"
-- if you have multiple box in selection do this
for i in selection do (i.name = uniqueName "myBox_")
-- how bout that as first step
-- then you open maxscript help , search "layer"
for as mentioned script above , its bit complicated but I believe by using "layer manager and name" function all could be done but it be little bit complicated since I need to "operate" your scene and know what you want to do with it exactly .
