hi
I would like to ask you if you knew any script or plugin to do this self-construction or self-generation of buildings
thank you very much
By snake_6969 · 2009-11-04
hi
thank you very much
try digimation grow plugin
Two scripts/plugins come to mind right away - "Building Generator" and "3D Architecture Animation Creator".
Building Generator will animate buildings that you generate with it - but won't animate an existing building. http://www.scriptspot.com/3ds-max/building-generator
3D Architecture Animation Creator - I haven't used it personally and it's a $100 but it looks like it'd do what you're looking for. http://www.3dbrother.com/
Of course this is the kind of thing that has tons of different solutions - from animated visibility / materials, to hand keyed pieces to using particle flow... The possibilities are really endless.
thank you very much for your prompt response.
Had also considered the possibility of visivilidad the material.
Proves the visivilidad and if not vere 3D Architecture Animation Creator Professional
thank you very much again and best regards
