Happy new year to everybody !
I was wondering if it is possible to make a modifier to select selection set.
Example :
I model an edit poly
on top I have a chamfer modifier.
Each time I select an edge to modify my model, i need to reactivate selection set.
If there was a modifier to do this it would be fantastic !
We could choose : subobject type, and selection set name.
Best regards.
Put a select or edit poly modifier beneath
Just put a "Poly Select" or "Edit Poly" modifier beneath the chamfer modifier and select your subobjects that should be effected by the chamfer modifier. Then work on the base model...
