Select odd/Even Splines segment
By Tricota · 2008-08-17
Hi Guys, i know this might be maybe a line, but I cannot get it work, I need the code to select odd/even spline segement.
Per example I want to do a Road Paint, so I create a spline, then Divide it, and then I have to select manualy every line in between to delete it and make the white painting. I know there should be a pretty easy script to do that
Thanks a Lot!!
Tricota
Comments (9)
olivier
Same but for vertices?
Can anyone explain how to do the same but for vertices? Cheers
Reply to olivier
You can use this fn (BTW works whit lines)
So select line and run the code
fn selectKnots spl which: = if isKindOf spl Line or isKindOf spl Splineshape do
	max create mode
	with redraw off for s = 1 to numSplines spl do
		setKnotSelection spl s #()
		for k = 1 to numKnots spl s do
			if which == #even then (if mod k 2 == 0 do setKnotSelection spl s #(k) keep:on)
			else (if mod k 2 != 0 do setKnotSelection spl s #(k) keep:on)
	max modify mode
	subobjectLevel = 1
After you run above function use next line
-- select all odd knots
selectKnots selection[1] which:#odd
or this line
selectKnots selection[1] which:#even
Thank you
YES! it works...seems to be a really long process to get it done by script but for what I need to do this is great!
Thank you very much for taking the time to reply with this!!!
Cheers
I doubt that it suports splines. Your snipped is more universal.
It is strange why AD not implemented all tools from PB?
Reply to miauu
I suppose they were busy with caddies :)
Christopher Grant
Here's a quick script that should do what you want assuming you only have 1 spline within your object (because it only works on the first spline sub object currently). In the example I tested I just created a quick line object, went to segment subobj and divided it, then ran the script.
To run this script, simply select your spline, and go to Maxscript / Run Script and run the attached file.
selsegs = #()
numsegs = (numSegments $ 1)
for i = 1 to numsegs do
	if (mod i 2) == 1 do append selsegs i --odd numbers only
setSegSelection $ 1 selsegs
