Hello all,
i'm quite sure this is something that most of you can write down in 2 seconds.
I have an exported dataset where dummies are presented by objects with 0 vertices. I'd like to get rid of them, therefore i'd need all of the (visible) objects with zero vertices to be selected so i can isolate or delete them.
Thank you in advance,
Marcin
Use Select Empty Objects button in FixUtilities script
FixUtilities included in TrackScripts pack
Download page: http://3d-kstudio.com/scripts/trackscripts
thank you so much!
to delete them: for i in
to delete them:
and to isolate/deselect them:
aww i was too slow :(
@le1setreter: after looking at your approach, i added the "clearSelection()" and deleted the "isHidden" check.
wieder was gelernt, danke :)
maybe this might help you:
