hello
I look for a script to select just one instance of an object :
- select all objects I want to work with
- run the script
- just one instance of each object is selected.
By titane357 · 2013-10-18
Comments (17)
So regarding Your code, I'm not maxscript master, I making my first baby steps in maxscript so I would need more explanation regarding this script:
fn reassignModifier mode: modyClass: =
local tsArr = getClassInstances modyClass
local objs = case mode of
#all:
if tsArr.count == 0 then #() else
for i = 1 to tsArr.count where (nodes = refs.dependentNodes tsArr[i]).count != 0 collect nodes[1]
#selection:
if selection.count == 0 then #() else
local firstInstances = #()
for o in selection where o.modifiers.count != 0 do
InstanceMgr.GetInstances o &firstOnly
if firstOnly.count > 1 then append firstInstances firstOnly[firstOnly.count-1] else append firstInstances o
firstInstances
if objs.count != 0 and tsArr.count != 0 do
max create mode
with redraw off
for o in objs do
for m = o.modifiers.count to 1 by -1 where isKindOf o.modifiers[m] TurboSmooth do
bulb = o.modifiers[m].enabled
mody = copy o.modifiers[m] ; mody.enabled = bulb ; deleteModifier o m ; addModifier o mody before:(m-1)
I created some objects with active turbosmooth, fired it up and I noticed script do preety much nothing:) I eresed
"addModifier o mody before:(m-1)" line 37 so cript should only delete modyfiers(it's only way for me to check if script work, because modyfier look identical before and after execution) but it seems script dont erase modyfiers. I have also impression that max don't touched this modyfiers - last script make it blink - there was some reaction on max modyfi interface . I don't even know is it working at all or it's work and I use it in wrong way? Next thing is, you gave to line for action on selection and action for all scene elements but how to use it, exactly, how to create two different script for this using this command. Next thing is script copy and paste this same turbosmooth. When there is skin glitch cased by turbosmooth - turbosmooth must be deleted and added new because contain glitch so if I copy and paste this same turbosmoothit is useless.So settings from oryginal turbosmooth mus be taken, old turbosmooth must be removed, new added and settings from oryginal must be set also check if turbosmmoth is active or not and set it identical.
I know my understanding of maxscript leave a lot to be desired but I'm beginner:)
Can You explane this script, please, maybe I just don't get it.
Don't retired, people need help:)
this solution works for any modifier class and both (selection and all scene)
You have two fn arguments: "mode" and "modyClass"
This will works only on selected objects
and this will take to acount all scene modifiers of specified class
BTW... This is my 15000 point on this forum (see "users by points").
Maybe it's time to retire. Why do you think?
Make your 15 001 post and post the code above in the right thread. :)
:) Yes. You are right! :)
This is the right thread:
http://www.scriptspot.com/forums/3ds-max/general-scripting/replacing-mod…
Or you can use instance trimmer from neil blevins script pack (which everyone should have installed already :-) )
Try this
if selection.count != 0 do
for o in selection do
if firstOnly.count > 1 do
if firstInstances.count != 0 do select firstInstances
Thank you very much ! :-)
Very Nice!
Could it me made to select all the objects that are not instances too?
so if I wanted to apply a modifier in all selected objects, that it would select the one instanced object like in the script and the objects that are not instances as well.
I could really use something like this.
Thanks!
Eric
Yup. Script select all non-instances object and first instace
Cool...how do I add this to the script below?
Which script below?
Thanks!
Using this fn U can do what you want
Now "objs" argument in fn represent array ei.collections of object.
If you want to consider only selected objects then run
to consider only geo-objects use
Still now working for me...
We are putting a script together to clean up imported CAD geometry. What we would like it to do is to selects all non instanced objects and a single instance of the instanced objects.
our goal is to select only the necessary objects prior to running the other scripts such as delete isolated verts, weld and smooth, flip inverted normal, quadrify ect...
I would appreciate any help.
Thank you!
I simplified fn and now it works fine
fn collectUniqueNodes objs = if objs.count != 0 do
local getNodeByHandle = maxOps.getNodeByHandle, getObjIns = InstanceMgr.GetInstances
local uniqNodes = #(), allINodes = #()
for o in objs do append allINodes o.inode.handle
while allINodes.count != 0 do
obj = (getNodeByHandle allINodes[allINodes.count])
getObjIns obj &firstOnly ; append uniqNodes firstOnly[firstOnly.count]
for o in firstOnly where (idx = findItem allINodes o.inode.handle) != 0 do deleteItem allINodes idx
uniqNodes
select (collectUniqueNodes objects)
This works!...1000 Thanks!
