select by submaterial
By appius · 2013-10-18
i wonder if it possible to write a scritp that would select all object including such or such instanced submaterial that stands in various multimaterials.
thanks in advance.
Comments (8)
draging
hello, try this one
select ( for obj in $* where classof obj.material == multimaterial collect obj )
is this what you want ?
cheers !
Reply to draging
Is not that simple.
He want to select by sub-Material not multimaterial
I'll post solution later
Reply to draging
Try this tool for change :)
How it works:
Press "Pick MultiMaterial" button and from "Material/Map Browser" (in "Scene Material" Roll) pick multi material or any sub-material of some multimaterial.
This tool will check if picked material are assigned already and check wether is belongs to a multimaterial.
Spinner represents sub-material index.
try(DestroyDialog ::mmtlSelector) catch()
rollout mmtlSelector "Select by SubMtl"
local mmtl
fn filtMtl mat = (isKindOf mat multimaterial or (for r in (refs.dependents mat) where isKindOf r multimaterial collect r).count != 0)
materialbutton choosemtl "Pick MultiMaterial" pos:[5,5] width:140
spinner mtlSubs "Sub Material:" type:#integer pos:[5,30] width:140 enabled:off
button btn "Select Object By Sub-Mtl" pos:[5,50] width:140 enabled:off
on choosemtl picked mtl do
if not filtMtl mtl then
messageBox "Pick Already Assigned Multimaterial Or Some Sub_Material " title:"Warning" beep:off
choosemtl.text = "Pick MultiMaterial" ; mtlSubs.value = 0 ; mtlSubs.enabled = btn.enabled = off ; mmtl = null
mmtl = if isKindOf mtl multimaterial then mtl else (for r in (refs.dependents mtl) where isKindOf r multimaterial collect r)[1]
choosemtl.text = if mmtl.name == "" then mmtl.name = ("MultiMtl_#"+(random 1000 2000) as string) else mmtl.name
mtlSubs.range = [1, (mmtl.materialList.count), 1] ; mtlSubs.enabled = btn.enabled = on
on btn pressed do
if isKindOf mmtl multimaterial do
if not MeditUtilities.isMaterialInUse (sub = mmtl.materialList[mtlSubs.value]) then
messageBox "This Material Is Not Assigned To Any Object!" title:"Warning" beep:off
select (refs.dependentNodes sub)
on choosemtl rightclick do (choosemtl.text = "Pick MultiMaterial" ; mtlSubs.value = 0 ; mtlSubs.enabled = btn.enabled = off ; mmtl = null)
createDialog mmtlSelector 150 75 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
waow! that was fast! you rock!
it seems to work fine. thanks a lot.
I just don't understand what's the choice between instance and copy.
it's a detection method? if so, the copy method never get results, even if I copy a submat from a multimat into an other multimat and after renaming it with same name...
Reply to appius
That's the default behavior of material/map buttons. Material Editor works also that way. U need to choose "Instance" because "Copy" will create new material which is unused in the scene
