select and detach vertices using maxscript
By zwrtron · 2019-02-09
Hello, is there a way to select certain vertices and detach them to new object using maxscript?
I have following geometry merged together (called boxes) and I would like to detach one of them to new object.
I would like to select all vertices of this geometry, where X-axis is possitive (right box) or negative (left box) and detach them to new object.
How can I do that?
Thanks!
Comments (10)
	global rol_detachByXpos
	try(destroyDialog rol_detachByXpos)catch()
	rollout rol_detachByXpos "Detach by X pos"
		local poDetachVerts = polyop.detachVerts
		local poGetVert = polyop.getVert
		button btn_detachPosX "Detach positive X" width:140
		button btn_detachNegX "Detach negative X" width:140
		function DetachVertsByXpos xSide: =
			if selection.count != 0 do
				selObjsArr = selection as array
				for o in selObjsArr where classOf o == Editable_Poly do
					vertsCnt = o.numverts
					posXBA = #{}
					negXBA = #{}
					for v = 1 to vertsCnt do
						vPos = poGetVert o v
						if vPos.x > 0 do posXBA[v] = true
						if vPos.x < 0 do negXBA[v] = true
					case xSide of
						#positive:
							if not posXBA.isEmpty do
								poDetachVerts o posXBA delete:true asNode:true name:(o.name + "_detachedPositiveX") node:o
						#negative:
							if not negXBA.isEmpty do
								poDetachVerts o negXBA delete:true asNode:true name:(o.name + "_detachedNegativeX") node:o
		on btn_detachposX pressed do
			DetachVertsByXpos xSide:#positive
		on btn_detachNegX pressed do
			DetachVertsByXpos xSide:#negative
	createdialog rol_detachByXpos
Reply to miauu
zwrtron
Thank you
Working like a charm exactly like I except.
But any chance to make it work on plane for example? Like it cuts plane in half which has edge in the middle (pos 0)
Figure:
https://i.imgur.com/9QKVTXl.png
Thank you so much!
Reply to zwrtron
Try this using Detach by Face:
		local poDetachFaces = polyop.detachFaces
		local poGetFacesUsingVert = polyop.getFacesUsingVert
		radiobuttons rb_detachBy "Detach:" labels:#("verts", "faces") default:1 columns:1
					posXBA = #{}
					negXBA = #{}
					case xSide of
						#positive:
								if rb_detachBy.state == 1 then
									poDetachFaces o (poGetFacesUsingVert o posXBA) delete:true asNode:true name:(o.name + "_detachedPositiveX") node:o
						#negative:
									poDetachFaces o (poGetFacesUsingVert o negXBA) delete:true asNode:true name:(o.name + "_detachedPositiveX") node:o
or if it not works as expected:
		local poGetFaceCenter = polyop.getFaceCenter
					facesCnt = o.numfaces
					posXBA = #{}
					negXBA = #{}
					for v = 1 to facesCnt do
						fPos = poGetFaceCenter o v
						if fPos.x > 0 do posXBA[v] = true
						if fPos.x < 0 do negXBA[v] = true
					case xSide of
						#positive:
								poDetachFaces o posXBA delete:true asNode:true name:(o.name + "_detachedPositiveX") node:o
						#negative:
								poDetachFaces o negXBA delete:true asNode:true name:(o.name + "_detachedPositiveX") node:o
Reply to zwrtron
Panteleev Sergey
you can simply create a copy of your object and apply slice modifier with remove bottom to original and remove top to copy
GIF click if it refuses to play
@jahman - Thank for contribution, that's the way I've been doing it manually until now.
However, do you think that this approach is more effective than @miauu script? Because using slice works on both editable geometry and primitives where the script only on editable poly.
Reply to zwrtron
Panteleev Sergey
I personally like slice approach since it isn't destructive.
The only problem to solve here is to align slice plane to world axis properly.
ref = copy $
addModifier $ (SliceModifier Slice_Type:2)
$.modifiers[1].slicePlane.transform = inverse ($.objectTransform * RotateYMatrix 90)
addModifier ref (SliceModifier Slice_Type:2)
ref.modifiers[1].slicePlane.transform = inverse (ref.objectTransform * RotateYMatrix 270)
Reply to zwrtron
	global rol_sliceOnXaxis
	try(destroyDialog rol_sliceOnXaxis)catch()
	rollout rol_sliceOnXaxis "Slice on X axis"
		local poSlice = polyop.slice
		function SliceAndDetach xSide: = with undo "Slice and Detach" on
				dir = normalize ([100,0,0] - [-100,0,0])
				for o in selObjsArr do
					o.split = on
					poSlice o #all (ray [0,0,0] dir)
					update o
					posXBA = #{}
					negXBA = #{}
					case xSide of
						#positive:
						#negative:
			SliceAndDetach xSide:#positive
			SliceAndDetach xSide:#negative
	createdialog rol_sliceOnXaxis
Reply to miauu
zwrtron
@miauu - Thank you very much, exactly what I've been looking for.
