Script to thicken UV edge Selection Edge display
By airbrush · 2013-02-08
Would love a script that modifies the UV edge display. The default thick option is still hard to see since the wire frame is overlay on top of the edge.
A script to modify desired thickness, color.
thx,
Jeff
airbrush
The default uvw unwrap modifier has the option to display thin or thick edges. There must be a way to thicken these even more if someone can pick apart the modifier??
The issue is only apparent when you are unwrapping, normal edge selection on geo itself in the viewport works fine and displays well.
much appreciated
Can you do this manually?
Also, can you post the picture wuth the problem?
Reply to miauu
airbrush
Actually, now that i look at it again, the subject needs to be changed.
What I would like is an option to vary thickness of the uv edge display(make thicker and always be on by default when you go into the unwrap), but also the main problem is just the selection highlight of the edges within max itself, it becomes very hard to see what you're selecting(see link...red highlighted edges).
Would like the edge selection highlight to be thicker so its easier to see.
https://www.dropbox.com/s/7pee90sqqfel630/SelectedEdgeDisplay.jpg
thx
