Script to select spline vertex based on type
By Eric · 2017-04-24
Hi!
I am looking for a script that will select spline vertices based on type. For example selecting only the corner vertices of a spline or just the bezier vertices of a spline. Any help would be much appreciated. Thanks!
Select the spline. Go to Vertex sub-object level, deselect all verts. Run this script:
	global rol_selKnotsByType
	try(destroyDialog rol_selKnotsByType)catch()
	rollout rol_selKnotsByType "Select knots by type"
		radiobuttons rb_knotsType "" labels:#("Corner", "Smooth", "Bezier", "Bezier Corner") default:1 columns:2
		button btn_select "SELECT" width:190
		on btn_select pressed do
			if selection.count != 0 do
				selObjsArr = selection as array
				for o in selObjsArr where (classOf o == Line or classOf o == SplineShape) do
					knotsToSelArr = #()
					splCnt = numSplines o
					if splCnt != 0 do
						for ss = 1 to splCnt do
							tmpArr = #()
							knotsCnt = numKnots o ss
							for k = 1 to knotsCnt do
								knotType = getKnotType o ss k
								case rb_knotsType.state of
									1:
										if knotType == #corner do append tmpArr k
									2:
										if knotType == #smooth do append tmpArr k
									3:
										if knotType == #bezier do append tmpArr k
									4:
										if knotType == #bezierCorner do append tmpArr k
							setKnotSelection o ss tmpArr keep:true
	createdialog rol_selKnotsByType width:200
Reply to miauu
Eric
Perfect! Exactly what I was looking for. Thanks a lot!
