Hello,
So... I'm trying to figure out the best way to organize objects in a scene into layers by their poly counts and then name those layers according to their poly counts.
So all objects that have 10 polygons would go into a layer called "PolyCount_010", objects that have 592 polygons would go into a layer called "PolyCount_592", etc.
Does anyone know of a script that can do this? Or at least maybe the best way to go about it?
Any help would be GREATLY appreciated!
Is this fn that you looking for?
fn organizeObjs objs layerName: =
local getLayByName = LayerManager.getLayerFromName
local newLayByName = LayerManager.newLayerFromName
for o in objs where canconvertto o Editable_mesh do
name = layerName + formattedPrint (getPolygonCount o)[1] format:"0.3d"
layer = if (lay = getLayByName name) != undefined then lay else newLayByName name
layer.addnode o
organizeObjs objects layerName:"PolyCount_"
:o .... You're a Script-God among men. This is _exactly_ what I was looking for. A thousand thank you's, barigazy. This is amazing.
You're welcome
Enjoy
Here are some useful bits of script that I have found so far (that other users have put together) to select objects with certain vert counts:
By User: Anubis
To select objects with more then 32000 vertices:
select (for o in geometry where \
(getPolygonCount o)[2] >= 32000 collect o)
By User: miauu
select (for o in geometry where ( o.numverts >= 32000) collect o)
By jkwiatkowski
To select objects with poly count lower than...:
fn selectByPolygonCount arrayOfNodes numFaceFrom numFaceTo = (
--clear selection
clearSelection()
--loop through array of nodes
for obj in arrayOfNodes do
tmpArr = getPolygonCount obj
numFaces = tmpArr[1]
if numFaces >= numFaceFrom and numFaces <= numFaceTo do selectMore obj
