Script to align a camera to 2nd camera and set a key?
By net_ralf · 2008-10-31
I have an animated camera with a look at constraint to a helpber. I would love to have a script that creates a camera that will be aligned on all axis to the already existing camera every 5th frame and set a keyframe for a certain framenumber. It is very important that there will be keyframes since its going to be used for importing it into fusion.
thx for any help in advance
Ralf
Anton Berg
I have made a small script that creates a new camera following the first camera. I should work even if you have special setup with a free camera and a lookat controller or many controllers.
I gueess that you are then exporting the camera as a .ase via file/export that you can import into fusion.
I have made and tested this script in 3dsmax 2009, it might work ok in older versions but it is not 100% certain.
To install:
Just drag n drop the script onto 3dsmax or choose /maxscript/run and browse to this script.
after it is run you can go to customize/customize user interface...
under category choose:
OS3D-Scripts
You should have a script called:
OS3D - Create a keyframed camera
add this to a toolbar or menu.
OgmaSoul3D
Anton Berg
