script speed is not good
By dussla · 2013-05-21
mysel = selection as array
for obj in selection do obj.layer.select true
$.ishidden = true
mysel.ishidden = false
in big scene , speed is very slow
is that good idea ?
Comments (7)
Use with redraw off
with redraw off
-- code here.
or use disableSceneredraw()/enbleSceneRedraw()
Reply to miauu
...hide unselected nodes in the own layer
Yup. As Kostadin said "with redraw off (/*...your code...*/)"
layNames = #()
for o in selection do appendIfUnique layNames o.layer.name
with redraw off
for i = 1 to layNames.count do
(LayerManager.getLayerFromName layNames[i]).nodes &theNodes
hide (for o = 1 to theNodes.count where not theNodes[o].isSelected collect theNodes[o])
free layNames
Reply to dussla
If you have problem then change 2nd line to
for o in selection where finditem layNames o.layer.name == 0 do append layNames o.layer.name
Reply to Branko Živković
wow man ... max 9
I did not know anything about mxs when I used this version. Maxscript is changed a lot since max9. You will have more problems with newer code.
Hey, Branko, if I remember correctly for CheckMate tools contest(TurboSquid), one of the requirements was the tools to support max7. :)
Max 9 with AVG extension is good enough.
