I have been wondering if there could be any live-solution, script or MCG that creates contours of a terrain.
That means you pick the terrain mesh, set a distance value, eg 1m, and we get height curves from the lowest points every one meter to the uppermost level.
Hi! I never thanked you for the suggestion. I was quite busy and tried it only recently.
It works very good.
However, if there is anyone skilled in MCG; can you tell us if there is something that there that supports contour creation? It doesnt need to be live - a refresh button could also work.
from memory it should be poss..with MCG
and i don't think you have to be highly skilled...
(done it early on but never bothered to release it...can't remember why...maybe it was too easy)
If it's fast, I would recommend you to release the MCG
The tool that was previously recommended is good but a little slow.
Maybe an MCG could offer more benefits
» faster
» less clicks, ie an update could update the curves instead of erasing the old and regenerating
Have you checked this: http://www.scriptspot.com/3ds-max/scripts/contour-generator
