Hey Guys,
I want to be able to turn off and turn on Diffuse map in the scene I am working on.
meditMaterials[7].texmap_diffuse_on = off
I want to be able to do this to the entire scene.
By Ash Mohammed · 2014-06-25
Hey Guys,
Comments (11)
And this?
rollout bgaRoll "Diffuse On/Off"
colorPicker diff_clr "Diffuse Color: " pos:[5,3] fieldwidth:46 height:12 color:[170,170,170]
button diff_on "Diffuse On" pos:[5,20] width:120 height:18
button diff_off "Diffuse Off" pos:[5,43] width:120 height:18
mapped fn collectMtl mtls clr:diff_clr.color state:on =
if isKindOf mtls VRayMtl do
mtls.texmap_diffuse_on = state
if not state then
if distance (mtls.translucency_color as point3) (clr as point3) != 0 then
mtls.translucency_color = clr
swap mtls.diffuse mtls.translucency_color
) else (swap mtls.diffuse mtls.translucency_color)
if distance (mtls.diffuse as point3) (clr as point3) != 0 then
on diff_on pressed do collectMtl (getClassInstances VRayMtl)
on diff_off pressed do collectMtl (getClassInstances VRayMtl) state:off
createDialog bgaRoll 130 65 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
This works! Cheers
turn of real world scale box in diffuse map
Hi, I'm no programmer! Can you show me how to modify the script so that I can use it to turn off all (or selected objects materials - even better) real world scale in diffuse map?
ie. meditMaterials[1].texmap_diffuse.coords.realWorldScale = off
Like this
mapped fn collectMtl mtls state:on = if isKindOf mtls VRayMtl do mtls.texmap_diffuse_on = state
button diff_on "Diffuse On" pos:[5,5] width:120 height:18
button diff_off "Diffuse Off" pos:[5,28] width:120 height:18
createDialog bgaRoll 130 50 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
This is perfect! thank you.
I have an paid freelance opportunity for script if you are interested. email me at ash@studiorendering.com
Thanks.
I not work as freelance scripter. Sorry
But U can ask any question here.
Thank you
All your help in many blogs are very helpful. Thank you.
is it possible to add to this script
for only material texture map its turning on and off can we change the diffuse color to 170 170 170?
humm.
This works but i want it to only change colors 170 to texmap_diffuse_on its turning off.
mtls.diffuse = color 170 170 170
I did'nt test this
mapped fn collectMtl mtls clr state:on =
if not state then
error
--Argument count error: collectMtl wanted 2, got 1
Hats off to you. Thank you for your help!
