Rotating into Perspective View
By tiagori · 2013-04-13
Guys,
Would be great if we had a script that allow us to model in orthographic view, then when we rotate/orbit the viewport, it switched directly to perspective view, intead of user view.
I know that i can just press P to convert it back to perspective, but its becames very annoying to press it every time!!
Thanks in advance!
Comments (9)
harumscarum
apparently is not working with the 2020 Max version
could it be fixed?
thanks
I have tested this and it works:
macroscript isVptToPerspVpt
category:"miauu"
tooltip:"isVptToPerspVpt"
buttonText:"isVptToPerspVpt"
	callbacks.removeScripts id:#callView
	fn userToPerspective =
		if viewport.getType() == #view_iso_user do
			viewport.setType #view_persp_user
			max tool zoomextents all
	callbacks.addScript #viewportChange "userToPerspective()" id:#callView
tiagori
oh man! This is great!!! Thanks so much!! worked like a charm!
Btw, is there a way to automatic "Z" when rotating??
thanks Barigazy!!
Reply to tiagori
Yup.
should do it but works when tou switch from user to perspective ei. only once
run this in listener
if you find this useful save it as *.ms and put inside scripts > startup folder
after all you need to use "Z" (zoomextents all) after "Alt+MMB"
can we zoom extent with using z
hi barigazy
first of all i was so much in need of this script i was going to post in the script wanted section
thanks so much for this wonderful script
but can we do away with z
thanks
viki
tiagori
i know...but you also need to press a key to go into perspective...i trying to get a more fluid workflow. It would be automatic and fast rotating the viewport from top or front view for example, very dynamic.
I prefer to use "V" and pick from the list.
