First off, I've looked around and cannot find any good information on what I'm looking for so if anyone has found something similar to what's described, please speak up.
I'm guessing it's not easily possible, but is there a way to modify the roll outs in the Editable Poly modifier? I would love the option of adding certain tools found in the ribbon to the roll outs for easy access. For example, the ribbon has the dot loop and dot ring features that would make perfect sense to have directly below the Ring and Loop buttons in the Selection roll out. This would also need the slider for adjusting the gap. There are plenty of other features from the ribbon that I could see being added to the modifier stack. If it's easy and can be done with a little scripting, please, please help me out. If it's not so easy, a nice custom UI with the ability to do this would something I would pay for and I know others I work with would like as well. If it's helpful at all, I believe the ribbon tools code can be found here:
Drive:\3ds Max\MacroScripts\Macro_PolyTools.mcr
may be you can do it with custom attribute or you can do re-making it by hand.
