hello freinds
i am seeking resource collect + relink bitmap script for network render
i know backbuner and dr render
my work process, didn't need backbuner and dr render
By dussla · 2012-04-24
hello freinds
Comments (7)
collect + relink +++
Hi!
FilePathFinder
heap size error
i installed script in max2012
but there is help size error
what problem?
You used the max x64 ?
This is error with memory.
Please generate a bug-report
FilePathFinder menu help ==> Create support request
or drag into viewport the maxscript SupportRequest.mse (c:\Users\USERNAME\AppData\Local\Autodesk\3dsmax\2012 - 64bit\enu\scripts\TrackScripts\FilePathFinder\)
Thanks for feedback
can you make simple version for max9
i need simple version for max9
ex)
1. copy map and enviroment image in specic foder
2. relink image
3. result window
FilePathFinder free version for max 9
For max9 you can use FilePathFinder (medium-version)
It is absolutely free for max 9 and 2008
For work in 3dsMax version 9 you need to load and install the free plugin
Avguard MAXScript Extension Package.
there is one problem
i test light version and medium version
it is good
but that didn't copy max file only.
other is good and relinked well.
Parent file, of course, not must be copied.
FPF copy all assets(include xref)
but parent file, of course, not must be copied.
