hi,
would love to have a script to create a layer from object name.
would be usefull for scenes linked to 3dsmax from revit.
By damien11235 · 2013-06-27
hi,
Comments (12)
Awesome :)
Thax miauu!!!
Ive searched for this everywhere and here you are with the perfect solution :)
You just saved me a ton of time trying to redistribute hundreds of objects to individual layers :)
Is it possible to get this function to work for groups as well? I tried but Im a no-good scripter so it failed.
Very appreciated!
It's fenomenal to see how much interest on the people involved on programming stuff!. Nice scripts miauu!. Keep going!
As is written in the script body - uncommend 2 lines
hi thanks a lot,
i need the script to create the layer from the object name and put the object in that layer too. :)
It is easy to works for multiple objects, but what do you want the script to do - only to create empty layers with the same name as the object's name, or th crete layers and to put the objects in its layer?
Anyway:
hi,
thanks a lot for the same. is it possible to have the script take multiple objects and do the same instead of one at a time.
there is another script which does it for materials
for m in scenematerials do
if LayerManager.getLayerFromName m.name == undefined
then NewLayer = LayerManager.newLayerFromName m.name
else NewLayer = LayerManager.getLayerFromName m.name
for obj in objects do if obj.material.name == m.name do NewLayer.addNode obj
saveMaxFile (getfilenamefile (maxfilename) + "_for_Revit.max") useNewFile: true
would be great to have something which is automated like the one above.
thanks a ton in advance.
Not working for Max 2019
I'm getting an error when using the script in Max 2019
-- Error occurred in anonymous codeblock; filename: ; position: 421; line: 17
-- Syntax error: at ), expected
-- In line: )
Anyone have a solution for this?
Can you post the code that not works for you?
I have tested this code in 3ds max 2019 and there are no errors at all.
The error seems to occur when I've selected multiple objects. With a single object selected it works fine.
This should work with selection of objects:
Yes, it works perfect now! Thanks for fixing the script!
