render size fix
By dussla · 2012-06-06
there is 3 problem
1. if i render scene
i use render outputsize;[1600 1200] command
but render dialog window did not changed that value
2.if i render scene
new window is made
that is some complex in my monitor
3. i would like to fix render position in my lcd monitor
but if i render scene , render window is center
is possible that fix ?
Comments (11)
Vojtech Cada
If you want to have only one
If you want to use only one VFB all the time, you have to have a variable refering to a single bitmap that all the separate scripts would have and access to. Like this:
my_vfb = bitmap 1 1 -- that's the variable
render outputSize:[1600, 1200] to:my_vfb
render outputSize:[2400, 1800] to:my_vfb
Note that the position of the window is measured as a position of its upper left corner so depending on the preset sizes it might not work quite as expected.
Reply to Vojtech Cada
dussla
thank you for good help
thank you
i wonder
can i make that grobal variable ?
i made 2 button , result is 2 render window~
on low pressed do
on high pressed do
Reply to dussla
Vojtech Cada
Yeah, of course you can make it a global variable, but that's only necessary if the low and high event handlers are parts of different scripts. If they both have an access to the same locals, e.g. if they are both used in the same rollout, just make it local to that rollout:
try destroyDialog ::renderPresetDialog catch()
rollout renderPresetDialog "Render Presets"
	local my_vfb = bitmap 1 1
	button low "Low"
	button high "High"
	on low pressed do
	on high pressed do
createDialog renderPresetDialog
This is what you need to do
render outputSize:[1600,1200] vfb:true pos:#vfb_center
For position you can use:
#vfb_upper_left
#vfb_lower_left
#vfb_upper_right
#vfb_lower_right
#vfb_center
#vfb_renderer_position
#vfb_vprimary_position
#vfb_vsecondary_position
If you want to use camera then:
render camera:$Camera001 outputSize:[1600,1200] vfb:true pos:#vfb_center
etc.
Read this topic from mxs help
new window is re made when i render
i would like to use 1 window for rendering
like quick render
example}
i made many preset
render outputSize:[3600,1200]
render outputSize:[4600,1200]
when i use that script , each vfb is made
i use 1 vfb only
i use 1 camera only
i use only 1 camera
for test rendering , i render many time
so i have to use 1 vfb window
i wonder
i put f9 button , renderer use 1 window.
but when i use script ( render last outputsize : [ ] ) . vfb window is made again
what problem ?
Reply to dussla
What about this:
outsize = #([160,120], [360,120], [460,120])
for i = 1 to outsize.count do (render camera:$Camera001 outputSize:outsize[i])
Are you need 1 vfb window or 3?
