rename multi/sub materials
By Harmalarm · 2009-01-23
hi there,
in a current project I am working on I am using a large multi/sub material. All sub materials are named 'standardmaterial' and have a different bitmap assigned to their diffuse channel.
Now I'm trying to rename all the materials according to their bitmap name, so the 'standardmaterial' needs to be replace by 'bitmapname'. Because the multi/sub material has more than 400 materials, it's obvious this needs to be automated.
is their any way I could call upon the diffuse channel bitmap name of the material and output that as the sub/material name by means of scripting? You should know that my scripting skills are poor and in a starting phase...
thanx in advance,
Harmalarm
Anton Berg
I have attached the basic code for doing this. I haven´t done any userinterface but just OPEN this script and try it out.
I works on the currently selected material in the material editor.
--------- the code snippet
--get the current selected material
--in the material editor slot
yourmaterial = medit.GetCurMtl()
numberOfSubMats = yourmaterial.numsubs
--how many submaterials exist in the selected material
for i = 1 to numberOfSubmats do
try
bitmapName = getFilenameFile yourmaterial[i].diffusemap.filename
yourmaterial[i].name = bitmapName
yourmaterial.names[i] =bitmapName
catch (
print ("could not set name for this material" + yourmaterial[i].name)
---------end code snippet
Reply to Anton Berg
Harmalarm
:O
I am overwhelmed by the fast response! It works exactly the way it should!
Anton, you saved me a lot of time. Thank you VERY much!
Harm Sollie
