Rename multiple object (only mesh) with FileName
By red_bucket · 2018-12-12
Hi Everyone.
At my company, Im working on the objects data base. It’s a big one : 17 500 .max files.
All my .max files have a good file name. By inside the files, I want the mesh to have the FileName.
I use “batch it max”. That allow me to run the following little script in every max file automatically :
SetSelectFilter 1
actionMan.executeAction 0 “40021” – Selection: Select All
$.name = maxFileName
$.name = trimRight $.name “.max”
When I have only one mesh in the file, no problem. it’s work.
But, when I have multiple mesh in the scene, the script goes wrong.
So, what can I add in the script if I want to rename multiple mesh with the same name ?
For exemple :
My filename is : test.max
in the file I want :
mesh1 : filename01
mesh2 : filename02
etc…
I really need your help. I can’t find any issues.
Thanks a lot
Adrien
This is the simple function for your problem
-- this FN affect all object in the scene
-- but u can change "type" argument ei. replace "objects" with geometries or selection or lights etc.
-- also depending on the number of objects on the scene your suffix counter will starts
-- for example if you have more then 1000 objects, first object wil have suffix counter 0001
fn renameObjects type:objects = if type.count > 0 do
	count = (type.count as string).count as string
	fName = getFilenameFile (maxFilePath + maxFileName)
	for i = 1 to type.count do
		type[i].name = fName + formattedPrint i format:("."+count+"d")
RenameObjects()
