Looking for a script that can rename current layer by object selected.
Rename layer.
By Andrew · 2013-03-01
Comments (7)
this one also should work
Yep but he ask for solution where can rename the Layer of current selected object,
if i understend correctly.
who knows :)
"rename current layer by object selected" sounds to me clear, but if it's as you say, then s'd be this one:
or maybe:
And also we need to check if...
if selection[1].layer.name != "0" do selection[1].layer.setname "New Name"
not necessary
The name of base layer is read-only and no errors come if we try to modify it.
I did not that (..no errors
I did not that (..no errors come if we try to modify it..). Thanks Panayot.
You can changege object layer name like this:
fn renameObjLayer obj newLayerName: = if (objLayer = obj.layer.name) != "0" do
(LayerManager.getLayerFromName objLayer).setname newLayerName
--example
renameObjLayer $ newLayerName:"tuxmask75"
