Remove Spikes in Mesh. Select by longest edge?
By jininjin · 2013-06-16
I haven't found anything on Scriptspot that you can select by edge length. I am trying to delete large spikes in a mesh that were generated from an autoretopo. I think the easiest way is to select long edges based on a threshold. Anyway to do this? I found one by Bobo but the link is dead.....
Select some faces and run the script. It will remove all non quads from the selection, so only quad faces will remains selected.
	if selection.count == 1 and classof (curO = selection[1]) == Editable_Poly then
		local selFacesBA = polyop.getFaceSelection curO
		local poGetFaceDeg = polyop.getFaceDeg
		polyop.setFaceSelection curO (for f in selFacesBA where (poGetFaceDeg curO f) == 4 collect f)
		redrawViews()
		messagebox "Select only one Editable Poly object" title:"Invalid Selection"
This will remove all quads from the selection, so only the non quads will remains selected:
		polyop.setFaceSelection curO (for f in selFacesBA where (poGetFaceDeg curO f) != 4 collect f)
		redrawViews()
Reply to miauu
jininjin
Thanks Miauu. This is exactly what I was looking for. Now I just need subtract quads from the selection and I should be good to go.
Reply to jininjin
You wants a script that will get selected faces and will remove the quad polygons from the selection, so at the end only tris and n-gons will remains selcted?
I can write this script, but will do it tonight.
Someone else can do it earlier. :)
