Hi there,
I'm very nooby to maxscript and so i need a very little help.
My target it's to rename different object randomly from 1 to 100.
I explain my problem. I have 10 box, 10 sphere, 10 cylinder...and when I rename it on
obj_### i have as result all the box named obj000,obj001,obj002 etc and after all the sphere like obj011, obj012 etc.
and I don't need that, i need then obj000 to be a box, obj002 a sphere, obj003 another box, and obj004 a cylinder ...and so randomly
any suggestion ?
(sorry for my english)
Tnx
Works perfectly, both,
Thanks you very much
Why you not use Tools - Rename Objects to rename the boxes, spheres and so on, as you want?
Hey, try this:
cheers,
Pixamoon
a bit simplified version
fn randomrename objs name: = if (count = objs.count) > 0 do
array = #()
while array.count != count do appendifunique array (random 1 count)
for i in array do objs[i].name = uniquename name
randomrename selection name:"obj_"
but I'm not sure if faster.
because it has to find all items in array by random shots. plus find if they not exist in second array.
It can take sec but it can freeze max too.
What you think ?
Best,
Pixamoon
PS. to not freeze max is good to use timestamp() inside of while and let it run only for max 1s (or more)
